Jon Matcho Posted July 14, 2006 Share Posted July 14, 2006 Weighted objects are useful during building, and I usually realize I need more weights after a layup is underway and end up reaching for paint cans, hammers, vices, heavy tools, etc. The plans even list 5 and 10lb weights as recommended tools! So... knowing my parents are avid garage shoppers, I gave them orders a couple weeks ago to look for 5 and 10lb weights. No results from that mission yet, but... on my way home tonight, I drove past a sign that said "FREE" beside a bunch of plastic weights AND a couple diver's leaded belts. Bingo! I now have some good weights for building and can put the diver's belts to use for when I need ballast when I'm finish. That is... if the lead doesn't go bad by then. Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
magnum Posted July 14, 2006 Share Posted July 14, 2006 Jon, I found a cheap way to weight things down was to save up old milk and orange juce jugs with the screw on caps. After washing them out, I filled them up with water and they work well. I keep about 12 of them and the weigh about 9lbs each and store under the bench easily also. They are also easy to grab with the built in handle. I used them with the bulk heads and place a piece of plywood over the peel ply and the jugs on top. Just a little trick I found. On with the build! Tom Quote "Time flys when your building" Link to comment Share on other sites More sharing options...
Jon Matcho Posted July 14, 2006 Author Share Posted July 14, 2006 old milk and orange juce jugs with the screw on capsThat is a GREAT idea!!! Definitely going to use it until I stock up on old gym weights. Just have to be a little careful that you don't spring a leak... Quote Jon Matcho Builder & Canard Zone Admin Now: Rebuilding Quickie Tri-Q200 N479E Next: Resume building a Cozy Mark IV Link to comment Share on other sites More sharing options...
