shender1 Posted March 10, 2004 Share Posted March 10, 2004 Does anyone know where I can find specs on the Defiant. I've done some google searches but all I seem to find is pictures or references but no performance data. I would greatly appreciate anyone who could point to a web site with this info. Also, Are there 2 models of the Defiant and if so what are the differences between them? Thanks, Sean Quote I'm not aware of too many things. I know what I know if you know what I mean. Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted March 10, 2004 Share Posted March 10, 2004 Originally posted by shender1 Does anyone know where I can find specs on the Defiant.....I would greatly appreciate anyone who could point to a web site with this info.....Are there 2 models of the Defiant and if so what are the differences between them? There are a few people (Harry Manvel among them) that hang out on the canard-aviators mailing list that are flying or building Defiants. Other than flying next to Harry on the trip from SQF to MQI the day before the Airventure Cup race, and looking over his plane, I know virtually nothing about the Defiant (other than it's slower than a COZY :-) ). I don't believe there are any Defiant builders/flyers on this forum. Your best bet is to contact people that have them. Quote Marc J. Zeitlin Burnside Aerospace marc_zeitlin@alum.mit.edu www.cozybuilders.org copyright © 2024 Link to comment Share on other sites More sharing options...
Jim Sower Posted March 10, 2004 Share Posted March 10, 2004 Email your questions to Forest Wilson in Atlanta. He's at 16fw@bellsouth.net He built his for years and years and has been flying for 2 or 3 years. Quote ...Destiny's Plaything... Link to comment Share on other sites More sharing options...
Aaron Posted March 10, 2004 Share Posted March 10, 2004 Search yahoo groups for DEFIANT_FLYERS Defiant, etc you should fine em. Quote Link to comment Share on other sites More sharing options...
No4 Posted April 20, 2004 Share Posted April 20, 2004 From the old RAF ad Engines 2 x 0-320 4 seats Empty 1600 lb Load 1270 lb Gross 2950 lb Fuel 115 gallons US Span 31.4 feet Wing area 133 ft Loading 22.2 lb/ft2 Power loading 9.2 lbs/hp payload full fuel 660 lbs Max cruise (70%) 184 kts Fuel flow cruise 17.8 gph range 1044 nm Econ cruise (55%) 168 kts Fuel flow econ 13.9 gph Range econ 1208 nm Climb (2950lbs) 1500 fpm Climb (2220lbs) 1900 fpm SE climb 2950 lbs 310 fpm SE ceiling 6500 ft SE climb 2200 lbs 550 fpm Stall 2950 lbs 64 kts Stall 2200 lbs 58 kts Time to build 2000 hrs plus Quote The Coconut King Link to comment Share on other sites More sharing options...
shender1 Posted April 20, 2004 Author Share Posted April 20, 2004 No4, Thanks for the numbers! I'll forward them to my friend. Quote I'm not aware of too many things. I know what I know if you know what I mean. Link to comment Share on other sites More sharing options...
JOHNSTEICHEN Posted June 23, 2004 Share Posted June 23, 2004 Are there 2 models of the Defiant and if so what are the differences between them? Thanks, Sean There is only One model of the Defiant. The Original prototype of Burt Rutan was called the Defiant I with all the plans built versions called the Defiant II. The "II" has been dropped. Rutan's original was a one off proof of concept and differs from the Plans built Defiant slightly. I think the canard, wings are longer, and there is a different toe in of the winglets on the plans version.. There are many variations of canopies and rudders among the builders however. Mine has 2 180 hp Lycomings with wood props. It cruises at 167 kts at 9000 ft. Weighs 1970 empty. Gross weight is 3000-3400 pounds. Fuel is 116 gals, climbs at sea level at about 2000 ft/min mid weight. Single engine service ceiling with those engines is about 8000 ft. Fuel burn at 75% power is 18 gal/hour. Great Airplane, nightmare to build. Joy to fly John Steichen N27ez@aol.com Quote Link to comment Share on other sites More sharing options...
mtorzews Posted June 24, 2004 Share Posted June 24, 2004 John, Why is the Defiant a "nightmare to build"? I realize it is bigger than a cozy, so build time would be longer. There are two engines instead of one. So extra engine install time. But the basic construction techniques and level of difficulty should be similar. What makes it more difficult? Quote Mike T Link to comment Share on other sites More sharing options...
JOHNSTEICHEN Posted June 29, 2004 Share Posted June 29, 2004 John, Why is the Defiant a "nightmare to build"? I realize it is bigger than a cozy, so build time would be longer. There are two engines instead of one. So extra engine install time. But the basic construction techniques and level of difficulty should be similar. What makes it more difficult? Double the engines, double the wiring. Level of difficulty is the same as a cozy. Same construction techniques. Although I can't calculate it acurately, the surface area that needs to be filled, sanded and painted is much larger. Double the cowls. Basically, everything has to be done twice. You have to buy 2 of everything. I estimate that I used at least 6000 hours of build over 5 years. I built a Varieze in 2 years prior to the Defiant. Took maybe 1800 hours to build that one. John Steichen Quote Link to comment Share on other sites More sharing options...
