dust Posted February 23, 2004 Share Posted February 23, 2004 Learned this years ago on the listserv. the wings are heavy on the back side of the spar, we did two things 1 two level blocks bondoed onto spar for future level reference, both back to front and left to right 2 installed spar down in the front by .2 degree, when the wings are attached, the weight of the wings makes the spar level after wing attachment. enjoy the build dust Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
macleodm3 Posted February 24, 2004 Share Posted February 24, 2004 Just out of curiosity... does this set up the correct angle while parked on the ground or while flying? Quote Andrew Anunson I work underground and I play in the sky... no problem Link to comment Share on other sites More sharing options...
dust Posted February 24, 2004 Author Share Posted February 24, 2004 yes enjoy the build dust Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
dust Posted March 2, 2004 Author Share Posted March 2, 2004 well, we installed another wing (the third) on plane day, with the spar forward be .2 and put the level on the wing and again0.0, life is good enjoy the build dust Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
