Ray Kouns Posted December 28, 2002 Share Posted December 28, 2002 I am a looking ahead a little on finishing of the plane. Just a quick question to the group. I am working on the wings at this time and noticed that the leading edge is not as straight as i would like.(small dips)How much fill is acceptable or am i just being paranoid? finishing of the plane has me more concerned than any thing i have done so far. Lookin at some of the sites on the net i see people putting on the fill very heavy. thank for your comments. Quote Link to comment Share on other sites More sharing options...
dust Posted December 30, 2002 Share Posted December 30, 2002 Well, I have started to finish the canards and my object it to fill the low spots and make all surfaces perfecto, without damaging the glass. So, I first lighty (i mean really lightly) sandblast to remove the shineys and then apply thickest micro, i add micro until it no longer shines on the mixing stick, make straight pencil lines every 3 or so inches and then sand with a 36 inch flat sanding board, mostly at a 45 degree angle, I move the board and roll it slightly as i go. The board stays straight to the canard but the motion of sanding is at a 45 or so degree angle. YOU can really feel it when the shape is right and the canard templet tells you the same thing When I reach glass, I stop and refill the areas that still have pencil lines (the low spots) and do it again. The pencil lines really help me and I also use them in furniture building. They can also tell you when to switch grits, when all of the lines are gone, step up a grit Mike Quote maker wood dust and shavings - foam and fiberglass dust and one day a cozy will pop out, enjoying the build i can be reached at http://www.canardcommunity.com/ Link to comment Share on other sites More sharing options...
